what format for HD?
Raiu
Okay, I am prepping a WD my pasport HDD 320gb.
1. What format works best with this size HDD on the 68r?
2. Some of you are going to tell me fat***, I remember seeing it some where but I did a search and google search and did not find the specific program that works best to achieve these format types.
Thanks in advance.
If you are on Windows, you can use easeus partition master. It's free and does all types of file systems. Try ext3
