What IP for DMZ ?
msjpt
On my network i have the following setup:
ISP Router > LAN > WAN > Draytek 2130 Router
Because my ISP Router does not allow Bridge or just Modem, i need to setup DMZ on the ISP Router to point to my Draytek Router.
Both DHCP on ISP and Draytek are turned off. Im using static ip's.
Regarding current configuration for IPs, i have the following:
ISP Router - IP: 192.168.1.1
Draytek Router - IP: 192.168.0.1 (its using as Static WAN IP: 192.168.1.2)
So my question is what IP for the Draytek Router should i set on my ISP Router? The Draytek LAN device IP: 192.168.0.1 or the Draytek WAN assigned IP: 192.168.1.2?
I don't know it it helps, but bellow i leave a Traceroute from my Computer to Google.com so you can see my network IPs:
C:\tracert google.com
A rastrear a rota para google.com [213.205.83.229]
até um máximo de 30 saltos:
1 1 ms 1 ms 1 ms Vigor2130.lan [192.168.0.1]
2 2 ms 2 ms 2 ms 192.168.1.1
3 * * * Timeout.
4 51 ms 59 ms 29 ms 192.168.225.53
5 48 ms 59 ms 59 ms 192.168.108.165
6 78 ms 59 ms 59 ms 62.169.65.233.rev.optimus.pt [62.169.65.233]
7 48 ms 59 ms 59 ms 213-205-83-229.static.net.novis.pt [213.205.83.2
29]
On your ISP router you should put the Draytek WAN IP, the IP that the router gave to it.
So, 192.168.1.2.
So, 192.168.1.2.
Hi Caple,
Thanks for your advice. I will use the 192.168.1.2 that is the IP given by my ISP Router to the WAN port on the Draytek Router.
I didn't know if i should use the IP given by the ISP Router to my Draytek WAN port, or is ishould use the Draytek LAN Ip: 192.168.0.1.
Now i know that i should use the WAN Given IP.
Does anyone else can confirm this information. Is this the right way?
De nada, portuga. ;)
Boa noite tb para ti ;) É bom ver tugas por aqui.
E já agora só cá entre nós (e todos os outros tugas aqui), vieram à 2 semanas instalar na minha empresa o serviço empresarial 4G da Optimus. Subscrevi o plano 50/10 e tenho médias de 25/9 o que já era esperado pelos testes iniciais.
Resumindo estou muito satisfeito com o serviço 4G da Optimus.. mas em relação ao router Huawei B593, embora pareça porreirinho é uma valente mer*** . Vejam lá que nos dias que correm, todas as portas deste router são apenas a 100Mbps e não Gigabit... enfim.. lá tem o cliente de comprar um switch gigabit para ter uma rede interna minimamente decente!
E mais uma vez obrigado pela ajuda!
Mais uma vez, de nada.
Mas sou brasileiro ;)
