Hi,What are some easy ways to create/edit files, make directories, etc in the JFFS partition?
To get the most out of your router you should install Entware.
There you can install the nano text editor, which will help you to create and edit all config files (incl. the one in JFFS) directly on the router.
With kind regards
Joe![]()
OP said easy, though. I've been using *nix for years and still can barely get around in vi without a cheat sheet. Nano, on the other hand, is truly easy.
What method to get cmd prompt to run vi?
Just login to the router using telnet or ssh and type "vi" on the command prompt. You may also go to the directory containing the config file you want to edit and type "vi <file name>, the vi will open the <file name>.
Hi,Can the "Tools - Run Cmd" tab in the webui also be used as a command prompt?
Thx.
Thread starter | Title | Forum | Replies | Date |
B | dnsmasq: failed to create listening socket for 192.168.1.1: Address already in use | Asuswrt-Merlin | 7 | |
L | How to create white list? | Asuswrt-Merlin | 11 |
Welcome To SNBForums
