what is this error message on openVPN?
SHAH
what is this error message on openVPN ? and how to resolve without restarting the router ? please help.
What message do you get if you place the mouse pointer over the yellow '!' ?
The error message will be in your System Log.
when i hover my mouse icon over it ...it says "ip/conflict"
Are you using static IP's on any of your devices?
If you are, you need to make sure they are unique IP's for each device.
If not, shut down the entire network including switches and any clients you have.
Now, plug in the modem, wait 5 minutes. Plug in the router, wait 5 minutes. Plug in the switches and then turn on each device / client you have. I would be checking that each one has internet access and doesn't have a conflict shown before I turned on the next one.
Well to help the OP a little you will get an IP conflict when you connect 2 networks that have their own DHCP servers that use the same IP subnet with overlapping IP addresses. Regardless if it is a star based networking or a tunnel between 2 networks make sure that the DHCP addresses assigned between one network and the other or between LAN and VPN clients are different but within the same subnet.
When connecting 2 networks it can also happen if both routers have the same IP address somewhere of if a client is on another network using the same IP subnet at the same time.
Okay, that is good info.
But how do you get:
From;
Im on openVPN :D:eek:
Okay, it's all good now. :)
im not using any kind of static ip on any device. My DSL modem is bridged with router. Router is the only device which has DHCP turned on.
This usually disappears when i restart the router.
What SEM is trying to say is that when you connect to another network with VPN (or any other way) you should have the IP ranges set up in the DHCP scope to not interlap with one another.
So if you have the 192.168.1.1 network for both your local and your VPN connection, one should be handing out IP addresses in the 192.168.1.1 to 192.168.1.124 range and the other should be in the 192.168.1.125 to 192.168.1.254 range. Including making sure that the routers on each end are not both using the 192.168.1.1 default as their IP address.
here is the error log. help.
Sep 6 15:43:29 openvpn[2115]: OpenVPN 2.3.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [eurephia] [MH] [IPv6] built on Feb 23 2015
Sep 6 15:43:29 openvpn[2115]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Sep 6 15:43:29 openvpn[2118]: UDPv4 link local: [undef]
Sep 6 15:43:29 openvpn[2118]: UDPv4 link remote: [AF_INET]78.46.46.106:53
Sep 6 15:43:30 openvpn[2118]: TLS: Initial packet from [AF_INET]78.46.46.106:53, sid=8d268270 58625dc1
Sep 6 15:43:30 openvpn[2118]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sep 6 15:43:31 openvpn[2118]: VERIFY OK: depth=1, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=hidemyass.com, name=HMA, emailAddress=[email protected]
Sep 6 15:43:31 openvpn[2118]: VERIFY OK: nsCertType=SERVER
Sep 6 15:43:31 openvpn[2118]: VERIFY OK: depth=0, C=GB, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=server, emailAddress=[email protected]
Sep 6 15:43:35 openvpn[2118]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sep 6 15:43:35 openvpn[2118]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 6 15:43:35 openvpn[2118]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sep 6 15:43:35 openvpn[2118]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 6 15:43:35 openvpn[2118]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sep 6 15:43:35 openvpn[2118]: [server] Peer Connection Initiated with [AF_INET]78.46.46.106:53
Sep 6 15:43:37 openvpn[2118]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Sep 6 15:43:37 openvpn[2118]: PUSH: Received control message: 'PUSH_REPLY,topology subnet,route-gateway 10.200.4.1,dhcp-option DNS 10.200.4.1,ping 10,ping-restart 90,redirect-gateway def1,ifconfig-ipv6 2001:db8:123::2/64 2001:db8:123::1,route-ipv6 2000::/3 2001:db8:123::1,explicit-exit-notify 2,ifconfig 10.200.5.21 255.255.252.0'
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: timers and/or timeouts modified
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: explicit notify parm(s) modified
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: --ifconfig/up options modified
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: route options modified
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: route-related options modified
Sep 6 15:43:37 openvpn[2118]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sep 6 15:43:37 openvpn[2118]: TUN/TAP device tun11 opened
Sep 6 15:43:37 openvpn[2118]: TUN/TAP TX queue length set to 100
Sep 6 15:43:37 openvpn[2118]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=1
Sep 6 15:43:37 openvpn[2118]: /sbin/ifconfig tun11 10.200.5.21 netmask 255.255.252.0 mtu 1500 broadcast 10.200.7.255
Sep 6 15:43:37 openvpn[2118]: Ignore conflicted routing rule: 78.46.46.106 255.255.255.255
Sep 6 15:43:37 openvpn[2118]: /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.200.4.1
Sep 6 15:43:37 openvpn[2118]: /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.200.4.1
Sep 6 15:43:37 openvpn[2118]: add_route_ipv6(): not adding 2000::/3, no IPv6 on if tun11
Sep 6 15:43:37 openvpn[2118]: Initialization Sequence Completed
