What is this warning?
OOo
Can someone please interpret for me what the below means and what I should do if anything. Can find much on web.
thanks
Mar 31 16:23:26 ovpn-client1[2184]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Mar 31 16:23:26 ovpn-client1[2184]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
thanks
If you have "ns-cert-type" in your OpenVPN custom config, change it to "remote-cert-tls server" assuming this is a client.
Warning is just letting you know the syntax has been updated
Sent from my LG-H830 using Tapatalk
