where entware packages gone?
Chrysalis
Tried to install 'iputils-tracepath6' which was in the opkg list but my repo list was out of date.
Ran opkg update and it updated but with 98% of the list removed now only about 10 packages total. :(
Old version of packages here.
http://wl500g-repo.googlecode.com/svn-history/r851/ipkg/openwrt/
new here - notice how empty it is
http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/
This fix is to edit opkg.conf
this line
src/gz openwrt http://wl500g-repo.googlecode.com/svn/ipkg/openwrt
to
src/gz openwrt http://entware.wl500g.info/binaries/entware
then run opkg update
seems that repo moved hosts
After opkg update && opkg upgrade you will be redirected to new hosting automagically.
If you don't want to run opkg upgrade for some reasons, please edit /opt/etc/opkg.conf.
Worked for me. I had to do it a few times:
opkg update
opkg upgrade (I guess this is where the redirect is done)
opkg update (So this fetches the new packet list)
opkg upgrade
The I did it once more to make sure all updates were installed, but that time it didn't do anything.
I noticed when running the opkg it tells me that this feed for entware is no longer supported effective October 2015. It wants me to update to entware-ng with a URL it lists upon completion. Is this something we/I need to do with my AC-66U router as I run transmission and other basic scripts with no issues right now. Can we run this upgrade to entware-ng on our devices or should we stay put for now? Thanks for any info. Cheers
Running latest Merlin Fork 15e by John
AC-66U
AC-66U
https://github.com/Entware-ng/Entware-ng/wiki/Upgrade-from-Entware
