Entware [SOLVED] Entware packages not updating - wget doesn't have https support
Phantomski
headscratching here a bit.
I suddenly can't update/upgrade Entware packages in amtm. I don't remember installing anything that would affect it on the FW 386.7-2 and it certainly didn't improve on 386.9. It just stopped working.
Using amtm, the Update/Upgrade of Entware packages produces an error:
Bash:
Downloading https://bin.entware.net/armv7sf-k2.6/Packages.gz
*** Failed to download the package list from https://bin.entware.net/armv7sf-k2.6/Packages.gz
Collected errors:
* opkg_download: Failed to download https://bin.entware.net/armv7sf-k2.6/Packages.gz, wget returned 1.
Running opkg update produces the same error.
https://bin.entware.net/armv7sf-k2.6/Packages.html is accessible.
If I try using wget directly as wget https://bin.entware.net/armv7sf-k2.6/Packages.gz it comes back with an error HTTPS support not compiled in.
When I tried to install wget-ssl from HTTP version of Entware repository using opkg install http://bin.entware.net/armv7sf-k2.6/wget-ssl_1.21.3-1_armv7-2.6.ipk it comes back with Package wget-ssl (1.21.3-1) installed in root is up to date.
Removing and reinstalling wget doesn't help either. What am I missing?
You've probably installed a conflicting version of wget from Entware. Remove it and try again.
Or use /usr/sbin/wget
Nope, not manually.
Symbolic link /jffs/configs/wget points to ../../opt/libexec/wget-nossl. Don't know why. If I change it to /usr/sbin/wget it works OK. Not sure why and what would change it.
System wget aka /entware/bin/wget (note the -ssl):
Bash:
wget -V
GNU Wget 1.21.3 built on linux-gnu.
-cares +digest -gpgme -https +ipv6 -iri +large-file -metalink +nls
-ntlm +opie -psl -ssl
Wgetrc:
    /opt/etc/wgetrc (system)
Locale:
    /opt/share/locale
Compile:
    arm-openwrt-linux-gnueabi-gcc -DHAVE_CONFIG_H
    -DSYSTEM_WGETRC="/opt/etc/wgetrc" -DLOCALEDIR="/opt/share/locale"
    -I. -I../lib -I../lib
    -I/media/ware3/Entware.2022.12/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/include
    -I/media/ware3/Entware.2022.12/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/include
    -DNDEBUG -O2 -pipe -mtune=cortex-a9 -fno-caller-saves
    -fhonour-copts -Wno-error=unused-but-set-variable
    -Wno-error=unused-result -mfloat-abi=soft
Link:
    -Wl,--dynamic-linker=/opt/lib/ld-linux.so.3 -Wl,-rpath=/opt/lib
    -L/media/ware3/Entware.2022.12/staging_dir/toolchain-arm_cortex-a9_gcc-8.4.0_glibc-2.23_eabi/lib
    -L/media/ware3/Entware.2022.12/staging_dir/target-arm_cortex-a9_glibc-2.23_eabi/opt/lib
    -lpcre
    -lz ../lib/libgnu.a
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://www.gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Originally written by Hrvoje Niksic <hniksic@xemacs.org>.
Please send bug reports and questions to <bug-wget@gnu.org>.
/usr/sbin/wget (note the +ssl/openssl):
Bash:
/usr/sbin/wget -V
-cares +digest -gpgme +https +ipv6 -iri +large-file -metalink -nls
-ntlm -opie -psl +ssl/openssl
Wgetrc:
Compile:
    arm-brcm-linux-uclibcgnueabi-gcc -DHAVE_CONFIG_H
    -DSYSTEM_WGETRC="/etc/wgetrc" -DLOCALEDIR="/usr/share/locale" -I.
    -I../lib -I../lib
    -I/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/arm-uclibc/stage/usr/include
    -I/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/openssl/include
    -DHAVE_LIBSSL
    -I/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/routerzlib
    -DNDEBUG -Os -Wall -DLINUX26 -DCONFIG_BCMWL5 -DDEBUG_NOISY
    -DDEBUG_RCTEST -pipe -DBCMWPA2 -DBCMARM -fno-strict-aliasing -marm
    -DCONFIG_NVSIZE_128 -DLINUX_KERNEL_VERSION=132644
    -ffunction-sections -fdata-sections
    -std=gnu99 -DASUSWRT
Link:
    -DHAVE_LIBSSL
    -std=gnu99 -DASUSWRT -lgcc_s -Wl,--gc-sections
    -L/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/arm-uclibc/stage/usr/lib
    -pthread -luuid
    -L/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/openssl
    -lcrypto -lssl
    -L/home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/zlib
    -lz ../lib/libgnu.a
    /home/merlin/amng.ac88/release/src-rt-7.14.114.x/src/router/arm-uclibc/stage/usr/lib/libiconv.so
When I removed the "other" wget by opkg remove wget-nossl it removed the symlink too and all works well. I'm quite certain I haven't installed the nossl version myself. Strange.
EDIT: Of course I did :rolleyes: - when I was using 384.xx, the NonSSL version was the only way to update Entware. Doh. Not sure why it worked for a little bit on 386.7-2, but hey, all good.
Ran into the same problem. Thanks for sharing the solution!!!
This didn't work for me still getting :
Upgrading syslog-ng on root from 3.38.1-1a to 4.2.0-1...
Downloading https://bin.entware.net/aarch64-k3.10/syslog-ng_4.2.0-1_aarch64-3.10.ipk
Upgrading terminfo on root from 6.4-1 to 6.4-2...
Downloading https://bin.entware.net/aarch64-k3.10/terminfo_6.4-2_aarch64-3.10.ipk
Upgrading column on root from 2.38.1-1 to 2.39-2...
Downloading https://bin.entware.net/aarch64-k3.10/opkg_2022-02-24-d038e5b6-2_aarch64-3.10.ipk
Upgrading zoneinfo-europe on root from 2022g-1 to 2023c-2...
Downloading https://bin.entware.net/aarch64-k3.10/glib2_2.74.0-4_aarch64-3.10.ipk
Upgrading libcurl on root from 7.86.0-1 to 8.1.1-1...
Downloading https://bin.entware.net/aarch64-k3.10/libpcre_8.45-5_aarch64-3.10.ipk
Upgrading coreutils-base64 on root from 9.1-1 to 9.3-1...
Downloading https://bin.entware.net/aarch64-k3.10/zoneinfo-asia_2023c-2_aarch64-3.10.ipk
Upgrading coreutils on root from 9.1-1 to 9.3-1...
Downloading https://bin.entware.net/aarch64-k3.10/libpcre2_10.42-1_aarch64-3.10.ipk
Upgrading libjson-c on root from 0.16-2 to 0.16-3...
Downloading https://bin.entware.net/aarch64-k3.10/haveged_1.9.18-2_aarch64-3.10.ipk
Upgrading libuuid on root from 2.38.1-1 to 2.39-2...
Downloading https://bin.entware.net/aarch64-k3.10/libsmartcols_2.39-2_aarch64-3.10.ipk
Upgrading libintl-full on root from 0.21.1-1 to 0.21.1-2...
Downloading https://bin.entware.net/aarch64-k3.10/libncurses_6.4-2_aarch64-3.10.ipk
Upgrading libopenssl-conf on root from 3.0.8-2a to 3.0.8-9...
Downloading https://bin.entware.net/aarch64-k3.10/libncursesw_6.4-2_aarch64-3.10.ipk
Upgrading libsqlite3 on root from 3400000-1 to 3410200-1...
Downloading https://bin.entware.net/aarch64-k3.10/libhavege_1.9.18-2_aarch64-3.10.ipk
Upgrading libopenssl on root from 3.0.8-2a to 3.0.8-9...
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/syslog-ng_4.2.0-1_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Check your network settings and connectivity.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/terminfo_6.4-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/column_2.39-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/opkg_2022-02-24-d038e5b6-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/zoneinfo-europe_2023c-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/glib2_2.74.0-4_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libcurl_8.1.1-1_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libpcre_8.45-5_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/coreutils-base64_9.3-1_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/zoneinfo-asia_2023c-2_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/coreutils_9.3-1_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libpcre2_10.42-1_aarch64-3.10.ipk, wget returned 4.
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/haveged_1.9.18-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download haveged. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libuuid_2.39-2_aarch64-3.10.ipk, wget returned 4.
* opkg_install_pkg: Failed to download libuuid. Perhaps you need to run 'opkg update'?
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/libsmartcols_2.39-2_aarch64-3.10.ipk, wget returned 4.
I've got exactly the same problem when i's doing 'opkg update' and I can confirm the solution works, and the troubleshooting process is crystal clear. Unfortunately, I'm still facing amtm server-diversion.ch is unreachable problem as well.
For me, this issue occurred when installing busybox on my ASUS ROG AX-11000 with asuswrt-merlin and Entware. The installation gave a warning that many of the items already existed so that was my clue. After running opkg remove busybox --force-removal-of-dependent-packages --force-removal-of-essential-packages everything seemed to work and ls $(which wget) gave /usr/sbin/wget while wget --version | head -n1 rendered GNU Wget 1.24.5 built on linux-gnueabi which shows that the busybox version was removed from the PATH. Interestingly, some tools still use a built-in version of busybox which was not damaged despite the warning that --force-removal-of-essential-packages provides. The new busybox from opkg provided BusyBox v1.36.1 (2024-07-23 11:34:57 UTC) multi-call binary while the built-in one provided BusyBox v1.25.1 (2024-07-31 19:51:29 EDT) multi-call binary. Anyways, I hope this helps someone.
