Which asus to buy next?
Diveblaster
Hi
My ASUS GT-AC5300 is giving up and I have to replace it.
I've been looking at GT-AX11000 PRO, GT-AXE11000 and GT-AXE16000
I find GT-AXE16000 a bit pricy for us atm so I would like to here from people that has GT-AX11000 PRO, GT-AXE11000. Whats the difference? I know that AXE has 6E wifi but are they similar or?!
Regards
Dive
I'd recommend either the GT-AX6000 or its non-ROG sibling the RT-AX88U Pro to tide you over until WiFi7 matures. Whichever is cheaper at the moment.
Thx
The GT-AX6000 here is absolutely solid, just so long as you can hide it so it doesn't get mistaken for a scutter from Red Dwarf - it is big and it is very definitely ugly!
I'm "hidden"ly running a rock-solid GT-AX6000. The only reason it's hidden as much as it is being it's the best place for it to operate. I feel only the antennas are what's ugly. Neither it nor it's cousin (which appears to actually command a bit more shelf space) are as huge and ugly as any of the models mentioned in the first post.
I'd wait for second wave 7 before spending bigger bucks for bigger and/or uglier.
