which netgear ac router is better for a very big house the nighthawk x6 or x8
If you have a very big house, a single router won't do it. Set APs in your house
I had an R8000, it could cover my 2605 Sqft home (Basement, Ground and an Upper Floor) pretty well in both 2.4/5Ghz bands. I had it placed on the top floor and I had ok signal even in the basement, at least good enough to stream Netflix in HD without issues. Then again I suppose building materials and the fact that some homes have a metal meshwork in the walls can have a significant impact on the range though.
Always depends on the infrastructure. I can run both X6 R8000 and X8 R8500 fine in a 2 storey 1950's UK home with thick walls and ceilings.
The X8 active antennas can certainly help by amplifying WiFi signals in the antenna. See
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
and attached PDF
and attached PDF
I hate these video they are always so exaggerated and always promise more than what is in the real unit. The speed is so fast that you need a seat belt so you do not fly out of the chair and the coverage is as big as the whole neighborhood gets the benefit of it.
Just saw the video again. I didn't see the exaggerations you state above.
Hmm strange i get this video
when open new window.
But i mean in general videos about Routers, the above video about antennas was correct my bad sorry about that.
Another option is a new product package that Netgear is offering through Best Buy which includes an R7000 with built in Powerline and a Powerline Access Point (which they call DST Dead Spot Terminator). In my experience if you have a large home you will get best coverage by use of a router and AP's placed appropriately. The challenge with AP's is that they require a hard wire connection to your network. The Netgear Nighthawk DST router takes care of that with its use of Powerline. If PL works in your home this is an excellent solution.
http://www.bestbuy.com/site/clp/netgear-nighthawk/pcmcat748300545896.c?id=pcmcat748300545896
Bob Silver
Netgear Networking Advisor
My house is 3200 square feet and I currently have the R7000. I bought the R8500 hoping for better coverage but it was pretty much the same, so I took it back.
Bob Silver
This is a pretty cool solution. I'm using something like it from TP-Link, but it's only 2.4Ghz. Once these are out for a bit and Netgear offers a separate head-end (rather than having to have a certain router), I'll be checking these out.
