Which option would stream to Apple TV faster?
wmarson
Which HD streaming option would be faster?
1) HD Movie rented via Netflix/iTunes played wirelessly through Apple TV?
2) HD Movie rented via Netflix/iTunes played hardwired through Apple TV?
3) HD Movie stored on local NAS drive played wirelessly through Apple TV?
Assume Wireless N and 40+ Mbps download speeds.
I hope this is enough information to make the determination. I'm just looking for theoretical-based feedback. Thanks in advance!
- Bill
What do you mean by "faster"?
If you're asking which method would be most likely to provide trouble-free playback it would be #2 for two reasons:
1) As claykin said, wired (Ethernet) will always provide a more reliable connection than wireless
2) A movie from Netflix / iTunes is probably encoded at a lower bit rate than a Torrented or ripped copy .
Thanks! My ultimate question is whether or not I should move my AirPort Extreme router closer to my home theater (as well as move my Internet entry access point to my home) so I can hardwire my Apple TV and PS3. Or, leave is where it is -- kind of far away and on a different floor.
You don't need to move the router, just run a Cat5e or better cable between your router and the HT location.
If you choose to run the cable, run 2. You never know what may coming out next year....
