RabidTreeMonkey
Edited: Advice please for a good wireless N indoor repeater
Edit: as the thread has progressed, our focus has shifted towards finding a powerful wireless N indoor repeater; hopefully of the non-WDS variety. We'd like to keep our budget for the repeater in the $100 or less range. Also, given that the furthest client is about ~70 feet and 4 walls away, we might need to run 2 repeaters staggered along the way and just accept the hit to total throughput. No matter the solution, we're hoping to keep total costs to around ~$200 or less. $250 would be a maximum.
Background: We recently moved to an old 1920s apt complex surrounded by several other nearby apt buildings. Lots of nearby wireless traffic (approximately a dozen other nearby networks). After looking through logs, I've noticed at least one unfriendly out there repeatedly attempting (unsuccessfully) to log on to our network via password guessing. Security is required around here. Prior to this post, I've read up via the forums here at SNB and a few other places along with Tim's great pair of articles on bridging, access points and repeaters. On to the questions.
Our Netgear wndr3700 works great for our home, but we need to extend the range of our wireless g "guest" network since we're going to be sharing our broadband costs with at least two neighbors in apartments 40+ feet away. Our plan is to buy two repeaters to broadcast the wndr3700's signal. All of us have apartments on the second floor, so it's only walls we're transmitting through, not floors. It's possible that another neighbor closer to the wndr3700 might join our shared internet connection crew and thus give us a much-desired closer location for positioning our closest repeater, but currently the most difficult connection/hop we've got to make is one of two choices. Either:
We're planning on buying two repeaters/access points/range extenders to give us good coverage. We've been looking into the EnGenius esr9850 and Asus rt-n13u as possible solutions but are open to other options as well. The 2.4Ghz wireless g signal is the focal point as none of the neighbors use 5GHz or wireless N equipment. It's only the wireless network that we need to extend, so using access points/LAN ports off whatever equipment we buy is completely optional. We're tempted to go with the Asus rt-n13u since it charted better in SmallNetBuilder's location E and F, but at the same time we're wondering if the EnGenius esr9850 might work reliably enough while providing for an easier setup (non-WDS and Tim's article as a guide).
Since the primary purpose of this wireless network is to provide bandwidth from the shared internet connection, we expect anything in the ~6-10Mbit range to be plenty sufficient. Both downstream households are light/modest users and simply need a reliable connection rather than high bandwidth. Originally, I wanted to run some CAT6 wire down to the other apts, but our building manager said "no" which has led us to this post.
Any help/advice is greatly appreciated
- ~45ft through two walls (one near the wndr3700 and the other closer to the first repeater location). I'd compare this hop to SmallNetBuilder's location D or E in the wireless testing.
- a straight line of ~75 feet through one window and one wall (with the wall being at the far end near where the repeater would be placed).
