HI all,
I am in the process of buying a TP Link ER707 router. The mail reasoning behing this is to have notifications when one wan fails.
I currenlty have two fibre suppliers and the Asus router does not notify you via push notifications or email.
I currently have 150 - 200 clients with 55% of these clinets on wifi and majority are IOT devices.
I have a TP LINK SG3428XPP-M2 v1.20 network switch
TP LINK OC200 controller
7 BR3600 Asus mesh routers
What setup would you recommend.
Setup A
ONT 1 and 2 connected into the TP Link ER707
TP link TP Link ER707 into WAN port of the ASUS BE98 ( Asus to do all routing etc)
ASUS BE98 set in Wireless router mode / AiMesh Router mode (Default)
Asus to switch / mesh routers
Setup B
TP link TP Link ER707 into network switch ( TP LINK to do all routing etc)
ASUS BE98 set to Access Point(AP) mode / AiMesh Router in AP mode
Im not sure which route to go with. I was thinking of trying Option B but dont want to go down a rabit hole if its not worth it.
Setup A
Setup B
