Why do we have cru as well as crontab?
chrisisbd
Why do we have cru in addition to crontab in asuswrt-merlin? Does it offer any additional features or is it just a (slightly) easier to use interface for creating cron jobs?
It's just easier to use in scripts. Otherwise you have to do that whole "export the crontab, modify it, write it back" procedure.
A simple way to manage your cron jobs is through the included "cru" command. Just run "cru" to see the usage information. You can then put your "cru" commands inside a user script to re-generate your cron jobs at boot time.
M Minimum crontab resolution 2 minutes? Asuswrt-Merlin 7
