Why my asus login screen has 2 WAN IP addresses?
michtsui
As per the photo, why the asus map shows 2 WAN IP in my ac68U router?
Because you're using a PPPoE connection.
Do you have VPN and DHCP both enable in WAN settings? It's enabled by default. Just disable it thus:
