Enough do that it’s a billion dollar market in 2023. All of the Wifi 7 routers have been selling out constantly since April.At the end of the day - 11be will be like 11ax and 11ac... a subset of features that win on the cost/benefit scale...
I don't know many people that are willing to spend $300USD or more on a wifi router - did the reseach, been there, done that...
Perhaps the communication breakdown centers on whether "MLO" means "multiple link operation" or "yet-to-be-ratified-Wifi-7-specific-implementation(s) of MULTIPLE LINK OPERATION". Using more than one link simultaneously /is/ multiple link operation. (One can readily do this with wires and fibers, too.) I don't believe the discussion, at this point, ever went beyond the general sense of it, unless it was until you started wanting it to be something either different or more specific.MLO isn't supported in the Intel 411 m.2 network card. At least, it's called "Intel® Double Connect Technology" from back then. Not the same thing, even if it superficially looks like MLO. Btw, this card was introduced in Q4 2021. A very long way off from the still uncertified WiFi 7 status of today.
L&LD said:
It is impossible to aggregate 2.4GHz and 6GHz on Channel 100. You're misunderstanding how this works. There is no contamination as you're defining it.
Words fail me to describe the arrogance of those statements.My 'authoritative sources' are logic and already defined terms regarding WiFi. And my insistence on not conflating cellular network 'similarities' with WiFi, and specifically, WiFi 7.
Yes, life is too short. Unfortunately, I have to moderate these forums, so can’t use the Ignore button as many others have done.I will not be providing those authoritative sources, life's too short. Search is free for all.
On the "contamination" point - of course it does, if you're aggregating 2.4 GHz and 6 GHz onto my Channel 100, then you're introducing all the latency and signal strength issues of those links into the aggregated connection. Maybe MLO is smart enough to use the high-performance band as an anchor and manage the rest intelligently, but I don't trust it, much rather not introduce the extra variables. I prefer stability over speed. And moreover, MLO probably requires the same power limit on all bands, so now my Channel 100 has to go down to 24 dbm, which kills its main advantage. It'll need to be tested ultimately, but I don't see how it can be as good as using a single channel.
Ok, so for the record you are saying that MLO or CA in cellular networks is not adding or aggregating several channels together? You're so adamant about this being wrong that I am curious what you think the actual correct description of these technologies is, in general terms. I mean it's literally called "multi-link operation", I feel like it's pretty self-explanatory, but I could be missing something.
I'm sorry you see as arrogance what I see as simple logic. The ignore button is not a feature I use.
Saying WiFi 7 and cellular aggregation is similar is like saying that a round rock is an early bicycle.
www.rcrwireless.com
Please save your condescension for those who choose to put up with it.I'm sorry you see as arrogance what I see as simple logic. The ignore button is not a feature I use.
Not sure how anyone could see it as anything else, it's combining multiple frequencies to increase bandwidth.“Qualcomm’s Vice President and General Manager of Mobile and Compute Connectivity Dino Bekis referred to multi-link capability as one of the core aspects of Wi-Fi 7 and suggested thinking of multi-link for Wi-Fi 7 as similar to how channel aggregation works in cellular networks.”
What is high-band multi-link for Wi-Fi 7?
Qualcomm’s VP and GM of Mobile and Compute Connectivity Dino Bekis referred to multi-link capability as one of the core aspects of Wi-Fi 7.www.rcrwireless.com
I guess the guy in charge of Wi-Fi 7 at Qualcomm is wrong then.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
