jojolafrite
[Solved] Wifi AC network speed slow due to windows seven
Hello everyone,
I have an issue during files transfer between my pc and a NAS since I decided to get an AC network.
According to what I read or found, I expected a transfer rate around 50 MB and today the max I can get is through FTP at 20MB. Through windows the best I had was during a full moon night with a rate of 16MB.
I really hope someone in your community can give me some solution as it drove me crazy.
Now I will try to give you the different detailed info about my configuration and the tests I already made.
Thanks in advance if you take time to read all the post.
Configuration:
Nas: it is a box provided by my ISP, its OS is based on customized linux.
PC: windows 7, I recently buy the asus pce-ac68 adapter (believing my old one based on the intel AC7260 chip was the root cause of my issue, obviously => Fail)
Router: asus RT-ac68u recently updated with the latest stock firmware. Since then the connection in AC is only possible on the Channel 36 (but due to my test I don't think it is the cause). I precise I am in France.
Environment: My PC is 22 feet far from the router (around 7 meters
). I am the only one broadcasting on the 5ghz band. I forced the 80MHZ. Wired connection is not possible permanently due to my apartment configuration and CPL neither due to my old electrical network.
Now the tests done:
- First I tried with a cable and the rate was around 30MB with windows explorer transfer (but I did not try to configure correctly my adapter and it seems seven requires it).
- I tried to measure the real network speed with some tests done with iPerf and after several tries, I obtain results between 55MB and 73MB (which is exactly what I expect). This test was done with the latest stock firmware of the router with the channel 36
- I changed lot of parameters, registry keys and so on in windows with notably:
Disable auto tuning
Disable receive-side scaling state
Remove RDC
Uncheck IPV6 for my pce ac68
Disable windows virtual miniport
Changing MTU settings
Try to disable Firewall and anti virus
So with all this modifications, I think about reinstalling windows on top of my existing install.
I tried to find some docs about the advanced settings (in adapter’s properties) of the asus pce ac68 but I found nothing describing each options. My card has the latest asus’ drivers available.
Could someone give me some ideas (the solution will be the best
) to finally reach the promised awesome rates?
Thanks a lot for your time by reading my post till there.
Hello everyone,
Configuration:
Now the tests done:
Disable auto tuning
Remove RDC
