Wifi dual wan
Paxsat
How can I use my neighbor's WiFi network as Dual Wan my Rt-N66U? (or usb wifi dongle)
Inviato dal mio SM-N7505 utilizzando Tapatalk
You can't. Dual WAN only works with a standard Ethernet connection, or a compatible 3G/4G adapter.
if use only web interface - yes.
but if use console or startup scripts:
- make dual wan (wan and lan4 for example)
- remove wifi from br0
- make br1 and add to br1 wan and wifi
- connect usb wifi-2 (if find compatible driver)
- make br2 and add to br2 lan4 and wifi-2
Can u help me? My usb wifi is dlink dwa-140. Ty ( I saw a tutorial where in ddwrt added a virtual interface wifi)
Sorry for my english (Google traslate)
I read about wds.... Like..
 iwconfig wlan0 mode Master
iwconfig wlan0 essid whateveressid
iwpriv wlan0 wds_add
brctl addbr br0
brctl addif wlan0
brctl addif wlan0wds0
ifconfig wlan0 0.0.0.0
ifconfig wlan0wds0 0.0.0.0
ifconfig br0
And
        # create virtual wlan adapter and run HostAP
iw phy phy0 interface add hostap.wlan1 type managed
ifconfig hostap.wlan1 down
ifconfig hostap.wlan1 hw ether 12:34:56:78:90:ab
ifconfig hostap.wlan1 192.168.0.1 up
hostapd /etc/hostapd.conf -B
# start DHCP and DNS
systemctl start dhcpd.service
systemctl start named.service
# connect to upstream AP
wpa_supplicant -D wext -i wlan0 -c /etc/wpa.conf -B
dhcpcd wlan0
# enable NAT
iptables --table nat --append POSTROUTING --out-interface wlan0 -j MASQUERADE
iptables --append FORWARD --in-interface hostap.wlan1 -j ACCEPT
echo 1 > /proc/sys/net/ipv4/ip_forward
with another usb wifi g (my old MovieCube - EMTEC)
Nov 16 16:08:57 kernel: usb 1-1.2: USB disconnect, address 5
Nov 16 16:08:57 kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Nov 16 16:08:57 kernel: option 1-1.2:1.0: device disconnected
Nov 16 16:08:57 kernel: usbcore: deregistering interface driver option
Nov 16 16:08:57 kernel: drivers/usb/serial/usb-serial.c: USB Serial deregistering driver GSM modem (1-port)
Nov 16 16:08:57 kernel: usbcore: deregistering interface driver usbserial_generic
Nov 16 16:08:57 kernel: drivers/usb/serial/usb-serial.c: USB Serial deregistering driver generic
Nov 16 16:09:03 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Nov 16 16:09:03 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Nov 16 16:09:05 kernel: usbcore: registered new interface driver usbserial
Nov 16 16:09:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
Nov 16 16:09:05 kernel: usbcore: registered new interface driver usbserial_generic
Nov 16 16:09:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
Nov 16 16:09:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
Nov 16 16:09:05 kernel: option 1-1.2:1.0: GSM modem (1-port) converter detected
Nov 16 16:09:05 kernel: usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Nov 16 16:09:05 kernel: usbcore: registered new interface driver option
Nov 16 16:09:05 kernel: drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.2
Nov 16 16:09:11 kernel: ACCEPT  <4>ACCEPT IN=ppp0 OUT=br0 <1>SRC=107.170.118.23 DST=192.168.1.2 <1>LEN=60 TOS=0x08 PREC=0x40 TTL=49 ID=27428 DF PROTO=TCP <1>SPT=45778 DPT=5900 SEQ=2195727546 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405AC0402080A5EEF4F9E0000000001030308)
