Ok, I have been tinkering with access points for the Wifi here at the house. We have alot of apple devices.. like four ipads, five iphones, a nest, two macbooks.. A few windows devices. Everything I can have as wired is wired.
I have tired using an amped wireless ap and it hasnt been very stable at all, it keeps dropping the ipads, causing streaming issues to them from the tivo stream. The nest hates the WiFi and keeps taking it self offline.
Has anyone got some suggestions as to a good access point to use in this kind of enviroment? I would like to try to get decent speeds from it.. handle a few users... I have thought about apples products, but I would like some input from others.
I dont really want to add a router and so forth unless its just the best option to turn off the routing part and use the wifi only.
thanks
thanks
