WIFI issues with devices
x7007
No matter what settings I do with 2.4Ghz it always time out like this totally random.
It's called Ambivision Pro + Magiclink device that it's a wifi camera watching the screen and leds behind tv light.
I had MikroTik and didn't have this kind of issue. only with the Asus AXE16000 it happening and it interrupt the smoothness of the light.
They are very close and nothing on the way.
I tried all kinda of settings, it works fine with WPA + TKIP all the security things off. but it doesn't fix those timeouts . it can be 20000 packets fine but then it will have like those
once before when I got the router it was much worse, all devices had high pings jumps from 1ms to 1000 suddenly , but I fixed it with disabling things and maybe fixes in the firmware.
1. Did you setup everything from scratch or just import your settings over again after returning to the factory firmware?
2. Have you tried using a different 2.5GHz channel?
