wifi mac addresses get scrambled after 44EA
Deleting the original post and replacing it with solved isn't very helpful.
How about you post the problem and the solution instead to help future users?
Just guessing, but probably coincides with their update to IOS 14, which randomizes MAC addresses for privacy.
well i wanted to delete the enire post but i was not able.
indeed the privacy issue in ios 14 was part the problem
i did not think of this before because i also had a problem with a ps4 playstation not getting a dhcp address from the router(solved it by giving it a static address)
somehow i still experience weird issues with dhcp since V44EA but can not lay my finger on it.
it seems that after a while my wireless devices(iphones) can not use wireless connection anymore(it is not working) while they are still connected.
the only way to solve this is to disconnect and reconnect again(what triggered the other problem with fake mac adresses)
i will do some testing to see if i can pinpoint it
played around with release times (1 day, 1/2 day) but this did not solve anything.
