Wifi scheduler
Benoitone
Hello,
I have a question:
Is it possible to define a period for stopping wifi on my RT-AC88U router?
Not daily, but from one date to another. For example to define a vacation period during which you want to turn off the wifi part of the router?
Almost anything is possible with RMerlin Firmware :p
Im pretty sure there is no option in the GUI for such a thing though, my best guess would be to write a script that disables/enables the radios that is run with a cron schedule of some kind.
Is it that important to you to disable the WIFI? If you are using WPA2 with a strong password you are unlikely to have unauthorized nefarious activity.
Thanks for your answers.
I will try to find a solution with script [emoji3]
It’s for energy saving.
Have a good day.
