WireGuard preshared key (password)
berez
I want to configure an additional password for the Wireguard VPN connection. Currently if I import the connection file on a Windows PC it is established without authentication with an additional password. In the VPN server options I checked preshared-key, but I don't see anywhere an option to set it.
I don't use the ASUS wireguard interface, but once the pre-share is turned on - try to export the wg config and see if the config file has a preshare key in it. Asus may be auto generating the key for you.
A RT-AX52 Wireguard Server Not Restarting After WAN Down/Outage ASUSWRT - Official 1
