Wireless N, VPN
  • Thread starter Thread starter jaileer
  • Start date Start date
J
jaileer
Guest
Hi All,
I'm looking for a Wireless-N router that has VPN. I'd like it to be gigabit, but that's not necessary. I'd also like true VPN, not VPN Passthrough. This will be used for a small business and one of the applications I'm going to use is Quickbooks. I've been looking at the Cisco 861W but wanted to post here to see if anyone had thoughts on that particular router, or an alternative.
Thanks!
The widest draft 11n selection is in consumer routers. I can't comment on the Cisco 861W since Cisco has not provided any product for review.
But you might be better off choosing a VPN router (I suggest looking at SSL-based products, such as the Linksys RVL200) and adding draft 11n wireless by converting a draft 11n router to an AP.
J Need new router with encode decode vpn Wi-Fi Buying Advice 14
