Wireless Repeater with outside antenna
Kshaw
My airplane hangar has an Xinfinity hotspot nearby. I can pickup a great signal when I am outside the hangar but the signals do not penetrate the steel siding. I am looking for a repeater with a connection to an outside antenna where I can pick up the outside signal but can connect to the internet inside the hangar. Anyone make something like this?
I would use a Ubiquiti NanoStation Loco on the outside of the hanger connected back inside with an ethernet cable. The LocoM2 is for 2.4ghz (which is what I would image the hotspot is) the LocoM5 is for 5ghz. This is directional so you need to point it in the direction the signal is coming from.
http://www.amazon.com/dp/B004EGI3CI/?tag=snbforums-20
Then use whatever wireless AP or router you want inside the hangar.
Just as a heads up - running a repeater on a public hotspot (xfinity or other) will impact everyone on that hotspot, cutting their bandwidth in half...
so be a good neighbor...
D Best wireless router for reliablity Wi-Fi Buying Advice 3
