Wireless Repeating/Extending options help needed
nikleb
I have a Netgear WAC120 AP that generally works well. However, after installing a security camera on the outside I found a deadspot. I have played with the AP placement, channels,.. and decided that I need some kind of repeater/extender solution.
I would like a solution that "learns" or applies my current MAC filtering on the WAC120. Also, I want to keep the same (un-broadcasted) SSID if possible. Is this even possible? Also, on same channel?
Therefore, I started to look at the Netgear EX6150. However, I also read the SMB article about the limitations of such devices.
I do have a network connection with a mini-switch nearby the deadspot. Does this open better possibilities? Simply adding another AP?
Adding an AP off your switch is the best solution, than any extender. Your ACL will still work, as the MAC address doesn't get changed / appended, like extenders and virtual MAC's..
Is this the bridge mode of the AP?
How will experience such a network when walking around with a mobile device? Will it automatically hop from one to the other radio?
Stay away from the NG Extender stuff. Purchase a router that supports Access Point mode. Once configured, Ethernet Cable the new AP to your switch. Clients either roam well or not. Some stick to current connection until the signal is so poor it actually looses connection. You may be able to use same SSID for your environment, or not.. Testing required.
Still a bit unsure on how to tackle the two AP setup.
This article shows a setup where there is a powerline com. instead of a wire to the wire. But how do I need to configure the master and slave AP to work as desired?
no just run ethernet to where its needed and run the second access point up with the same ssid and password just use different channel to that of the primary APeg one on ch 1 and the other on say ch 6 or 11
But how will AP2 "learn" the MAC filters form AP1?
now are you talking access control type filters or just wlan mac address filtering ?
as wlan mac address filtering is about as useful as tits on a bull lol
suggest you have a read of this
The six dumbest ways to secure a wireless LAN
http://www.zdnet.com/article/the-six-dumbest-ways-to-secure-a-wireless-lan/
will give you a guess what the number one dumbest way is :eek:
suggest if its just to secure your wlan just use wpa2 wireless security with AES encryption
No disagreement. But I do like the double-door idea. One other usage I have is to manage who gets to use my 5Ghz radio.
So, I ended up with a second WAC120 AP. My problem spot is solved.
However, I am surprised about the difference how devices behave in switching between my two AP's. It seems that it takes a lot for a device to switch to the better AP, hanging on to the old radio. In particular, Apple devices seem to really stick.
