T
thejinx0r
Guest
I need help with remote desktop connection (RDC).
So, here's my situation.
I just bought a new computer that's going to be used as a server (Windows XP Pro, might use it to stream games over network later).
I have Wake-on-lan working. Once the computer is up, at the login screen, I try to remotely connect, but it gives me an error saying that computer is not turned on or does not have RDC enabled.
So, I physically logon to the server. Go back to my other computer and RDC works.
Is there a way to logon to RDC without having to initially login physically?
