Currently running my Router RT-AX86U Pro (Asuswrt-Merlin 3006.102.4) with a Wireless AiMesh node RT-AX58U (Asuswrt-Merlin 3004.388.9_2). I understand there have been some compatibility issues reported with using the WPA2/WPA3. I, too, had some issues running on some of the earlier builds (can't remember now if it was on an update to the router or the node), but I had changed my main wireless setting on both the 5GHz and 2.4GHz to WPA2-Personal only. However, up until today, I did not have any issues with the clients on my Guest Network (which is shared with the node) with a setting of WPA2/WPA3, until today. So, now, after running smoothly since over a week when I upgraded from the Beta to 3006.102.4, the following happened in the log:
With the Router and Node MAC's obscured.
I have no idea what those log entries mean but after this happened, I had two IOT devices bound to the node that refused to reconnect, even after I rebooted the node. I have since updated the GNP settings wireless settings to WPA2-Personal and they reconnected. I don't mind having to change this setting, but I thought I would share this information in case it would help debug the issue for future releases (assuming anyone at Asus reads this and I am guessing this is not something that can be fixed within the Merlin codebase).
Rung
May 19 09:24:16 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 0
May 19 09:24:16 kernel: dealloc_netinfo enter wdev=0000000098ebe9a1
May 19 09:24:16 kernel: dealloc_netinfo exit iface_cnt=2
May 19 09:24:20 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
May 19 09:24:49 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 2 wfd_idx 0
May 19 09:24:49 kernel: alloc_netinfo enter bssidx=0 wdev=00000000f1c64220 ndev=000000002da43e72
May 19 09:24:49 kernel: alloc_netinfo exit iface_cnt=3
May 19 09:24:49 kernel: wl_pktfwd_lut_ins: DA=SYM<<Node's 2.4GHz MAC>> to roam from eth6 to wds0.0.1.
May 19 09:24:50 kernel: Invalid ndev status 4
May 19 09:24:50 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 0
May 19 09:24:50 kernel: dealloc_netinfo enter wdev=00000000f1c64220
May 19 09:24:50 kernel: dealloc_netinfo exit iface_cnt=2
May 19 09:24:51 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
May 19 09:24:51 kernel: Register interface [wds1.0.1] MAC: <Router's 5GHz BSSID MAC>
May 19 09:25:04 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 2 wfd_idx 0
May 19 09:25:04 kernel: alloc_netinfo enter bssidx=0 wdev=00000000b7a02c85 ndev=0000000062ec4e84
May 19 09:25:04 kernel: alloc_netinfo exit iface_cnt=3
May 19 09:25:04 kernel: wl_pktfwd_lut_ins: DA=SYM<<Node's 2.4GHz MAC>> to roam from eth6 to wds0.0.1.
May 19 09:25:10 kernel: No wdev corresponding to bssidx: 0x0 found! Ignoring event.
May 19 09:25:10 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
May 19 09:25:10 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
May 19 09:25:10 kernel: Register interface [wds1.0.1] MAC: <Router's 5GHz BSSID MAC>
May 19 09:25:22 kernel: Invalid ndev status 4
May 19 09:25:22 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 0
May 19 09:25:22 kernel: dealloc_netinfo enter wdev=00000000b7a02c85
May 19 09:25:22 kernel: dealloc_netinfo exit iface_cnt=2
May 19 09:25:34 kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
May 19 09:25:57 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 2 wfd_idx 0
May 19 09:25:57 kernel: alloc_netinfo enter bssidx=0 wdev=000000005e700792 ndev=0000000043950318
May 19 09:25:57 kernel: alloc_netinfo exit iface_cnt=3
May 19 09:26:00 kernel: wfd_registerdevice Successfully registered dev wds1.0.1 ifidx 2 wfd_idx 1
May 19 09:26:00 kernel: Register interface [wds1.0.1] MAC: <Router's 5GHz BSSID MAC>
Rung
