WPS broken in 386.7_2
tomek
Hi all, as per the title, after 2 days of fight including multiple full factory resets of both my ac5300 and brother printers, I gave up. Last time I used WPS to reconnect my printers was about 2 years ago, worked seamlessly then.
The only post i managed to find, exactly the same symptoms i’m experiencing, suggests downgrading to 386.1_2: https://www.snbforums.com/threads/wps-not-working-stuck-on-connection-status-idle.75966/
Seems nobody with Merlin firmware on snbforums is using WPS :) or people generally prefer connecting peripherals using ethernet (unfortunately not an option here due to the lack of space near the router).
Any ideas if there is anything else I could try?
If WPS is not working properly, perhaps this is the issue with AiMesh wireless node discovery in Asuswrt-Merlin?
@RMerlin
I think the only option bar downgrading firmware might be to take the pain and enter the password at the printer. over 70 random mixed case characters on a small display without alphanumerical keyboard will take just under 2 hours :-) This, or fallback to powerline adapters :-(
What? This is not needed and only creates inconveniences for you. :rolleyes:
