XT12 Pro - Multicast routing support?
MaleHumanUK
Looking to purchase the ASUS XT12 Pro mesh set.
I require support for Multicast Routing and IGMP snooping. Does anyone know if the XT12 has the ‘enable multicast routing’ option?
I can see IGMP snooping and Multicast Rate(Mbps) choice in 'Professional' Wi-Fi settings, as well as Enable multicast routing in LAN>IPTV settings, is that what you need?
Yes, I am very happy with them, much more pleased than with XT8 before as they're very stable, have great range and performance so far, work well with AX11000 in my set-up. Shame there is no USB port though, a very strange omission, as otherwise they ARE the best Wi-Fi 6 routers around, mesh or not.
Hi @Stepalex. It is likely a long shot given that I am responding to this thread a year later, though I was wondering if you could confirm if you navigate to LAN (under Advanced Settings) > IPTV (tab) > Choose IPTV STB Port = select any port (e.g. LAN1) > does Enable multicast routing further down change to Disable with a message: Due to hardware limitation, IGMP proxy cannot co-exist with IPTV function?
