XT8 guest network at satellite nodes?
DiegoSurfer
I've heard the new 386_26044 firmware fixed the known issue of not being able to get the guest network to the satellite nodes of the XT8. However, I can't seem to get it to work on my units. Does anybody here know if that functionality was added? thanks, I use the guest network for IoT devices to keep traffic somewhat isolated.
Who did you hear that from?
Probably safe to ignore. :)
If you want to prove it one way or another on your network, do a full reset on the main and each node and see if it works then (do not use a saved backup config file afterward).
The new firmware says guest network should work on all nodes. I installed the firmware but no luck. Tried a hard reset, still no luck. Anybody else out there get it to work?
If you haven't already fixed this here is how I enabled the Guest on all Nodes.
Log in to the router in a browser.
Go to Guest Network.
Click on the network (It's not always obvious that you can click there)
There is a setting Sync to AiMesh Node and change to all.
It worked in getting my guest network on all nodes.
that worked! thank you! is there any downside to enabling guest network at the nodes? Does it affect my regular network performance?? thanks so much! that totally fixed it
