Yamon3 assistance
macbean
I tried to install this the other day and couldn't get it to work. Now I'm back at it with a few questions.
First off, I am using a RT-AC68U, running 380.68_4. Entware is installed and everything is currently working fine.
When Yamon3 is installed, what webserver is it using? I'm assuming its the one used for management.
the yamon documentation states that the page will be at http://192.168.1.1/user/index.html and obviously the IP itself will be different if I've changed my range. But what if I'm enforcing https and using a different port? again, i've been assuming the full url would change.
And to add to it, if i'm using nginx as a reverse proxy, where does that fit into the picture?
