YazFi YazFi v4.4.9 [2025-Nov-08] - Enhanced AsusWRT-Merlin Guest WiFi Networks
Martinski
Release Notes for YazFi v4.4.6 production release now available
[2025-May-29]
The fork from @Jack Yaz's repository is now hosted on the AMTM-OSR GitHub repo:
1) FIXED: Problem where setting the "Allow Internet Access" option to "NO" was causing problems with the Guest Network clients being unable to communicate with main LAN clients and vice-versa if setting the "Two-way to Guest" option to "YES."
2) FIXED: Issue with "missing vertical scrollbar" on browser windows when the webGUI page was loaded on the latest 3004.386.14 F/W version.
3) FIXES & improvements to address the problem where, under some circumstances, the Hostname and/or the IP address values for a currently connected client are shown as "UNKNOWN" even though the network client was in fact connected to the correct Guest Network.
4) IMPROVED: Modified code to determine correctly all the supported wireless interfaces for new router models.
5) IMPROVED: Modified code to get the full current F/W version installed for comparison purposes because the latest F/W "3006.102.x.y" version string was generating wrong results when compared with older "3004.386.x.y" and "3004.388.x.y" F/W versions.
6) IMPROVED: Modified code so that every time the SSH CLI menu is run, it checks if the WebGUI page has already been mounted. If not found mounted, the script will run the code to remount the WebGUI.
7) IMPROVED: Added "export PATH" statement to give the built-in binaries higher priority than the equivalent Entware binaries.
8) IMPROVED: Various code improvements & fine-tuning.
NOTE:
YazFi is currently *not* supported on the latest 3006.102.x F/W releases.
It's great to see this release.
May I use the install line
/usr/sbin/curl -fsL --retry 3 "https://raw.githubusercontent.com/AMTM-OSR/YazFi/master/YazFi.sh" -o /jffs/scripts/YazFi && chmod 0755 /jffs/scripts/YazFi && /jffs/scripts/YazFi install
to install over my existing YazFi 4.4.4?
Why not just update via latest AMTM?
I didn't use AMTM to install YazFi initially (because I was unaware of it), and I just used the install instructions from the github. I just want to make sure I won't end up with 2 separate YazFi installs that will really confuse the router.
EDIT: Running it from AMTM, it pulls up the existing Yazfi installation and configuration page. Even though that page displays the old Yazfi github location on the text splash screen, it does register the new update 4.4.6 is available from the new fork location. So pretty assured the update would work as intended.
It sure does. amtm is built to automatically detect any addons it supports. Even if installed the old copy-paste way.
While you‘re at it, see all the features and other scripts amtm offers.
It makes no sense to have the guest wifi feature only on the main router and not extended to all nodes
Not everyone uses AiMesh.
AiMesh, I think, is closed source from Asus so its not clear how much customization (if any) can be done to the AiMesh node WiFi (or its WiFi clients) from the main router.
Release Notes for YazFi v4.4.7 production version now available
[2025-Jun-18]
1) FIXED: Prevent installation and startup of YazFi on the 3006.102.x F/W versions.
The F/W version check during installation and startup will also display an error message when YazFi script is executed on the 3006.102.x F/W versions.​
2) IMPROVED: A warning message is displayed at the startup of the CLI menu when detecting that a wireless radio is down or disabled.
3) Miscellaneous code improvements & fine-tuning.
The fork from @Jack Yaz's YazFi add-on is now hosted on the AMTM-OSR GitHub repo:
Nice job. People trying to install YazFi to 3006 has come up once or twice in the past.
Thanks. It was really overdue. This F/W check had been in the back of my mind for some time now, but I kept putting it on the back burner, especially once the AMTM-OSR migration work with the orphaned scripts got underway.
BTW (just FYI), as of today, 12 add-ons have been (or are in the process of being) "resurrected" - so the "to-do" list for the OSR team was long, but we're slowly getting it done.
Release Notes for YazFi v4.4.8 production version now available
[2025-Jul-21]
1) Improved messaging to show the uninstallation command when YazFi is *not* supported on the current F/W version.
Sample screenshots:
And, of course, the YazFi help command is available to see the full list of commands:
** The fork from @Jack Yaz's YazFi add-on is now hosted on the AMTM-OSR GitHub repo:
Any possibility of YazFi to be supported on 3006 fw in future?
No. Much of the functionality is already in the firmware.
Release Notes for YazFi v4.4.9 production version now available
[2025-Nov-08]
1) IMPROVED: Removed old Tomato JavaScript file references.
2) Miscellaneous code improvements.
Any chances for WireGuard support, please? OpenVPN is 5 times slower than WireGuard on my RT-AXE95Q.
It might be possible using iptables to router YazFi clients to a Wireguard entry. See my post (and additional discussion) at the following link.
