Zenwifi node connects to wrong router
lindstroem
Hello
I have 3x Asus ZenWiFi AX XT8
The Mainrouter is situated on a window frame to have clear connection to node C and is fairly close to node B (apart for some walls in between). Node B and C hade alot of concrete in between so they do not communicate efficiently.
I have setup the prefered connection for both XT8.2 & XT8.3 to be XT8.1, like this:
XT8.1-----------------XT8.3
XT8.2
But then instead some of the times the routers disregard this setting and connect like this which turns down the connection speed from 250/250mbit down to a very sketchy and failing 17mbit.
XT8.1-------------XT8.2--------------XT8.3
When the error occurs I try restarting the nodes and choosing optimize but they often fail that and revert back to the incorrect setup.
Do anyone have any advice on how to solve this??
Thank you in advance!
Preferable uplink AP set?
