makeitallwork
Setup:
- ZenWiFi XT9 w/ 3 XD5 for added coverage
Ideal configuration:
1) Primary Mesh network for limited devices w/ assigned IP addresses (no problem)
2) Guest Mesh network for Airbnb guests (no problem)
3) Guest Mesh network for IoT devices w/ assigned IP addresses (ISSUE)
ISSUE1: It seems Asus only allows Guest Network 1 to operate as a mesh network? The option to enable "Guest network on AiMesh" is not available for Guest Network 2 and 3? Am I missing something?
ISSUE2: I can assign IP addresses for the Main Network and Guest Network 2 (non-mesh), but the assigned IP addresses seem to be ignored for Guest Network 1.
QUESTIONS:
- Am I understanding the Asus limitations correctly?
- Anyway for me to implement my ideal configuration? (Running scripts and modifying the router firmware is probably outside my ability)
- Seems its best for IoT devices to have a fixed IP address. If the limitations above are correct, I assume the IoT devices should go on my Primary Mesh network vs Guest Network1?
Thank you!
QUESTIONS:
Thank you!
