Zyxel USG 50 Configuration Question
rnichols
I have had the Zyxel Zywall USG 50 for awhile now, and I am just now getting around to configuration of it more in depth.
I was wondering on the LAN ports that it has can you do some sort of Link Aggregation or Load Balancing with them? Or is this something that is only used on the NAS boxes?
Does anyone have any suggestions on how to make it a more secure router other than the basic firewall settings? Something that someone wouldn't normally think of for a home environment that would be helpful?
What do you guys think about the anti virus scanner on it? When I used to use it at our old house and I did a before and after speedtest the scanner dropped the speed from 150 to 115mbps on a cable modem.
