378.55 upgrade/downgrade issues
TheGrave
For some reason I'm stuck at 378.55. No matter which version I pickup for downgrade/upgrade it fails. Router is RT-AC66U. Any clues how to troubleshoot failed upgrades?
Cheers
Cheers
From where are you trying to flash the new version? If you haven't been using the CFE, try that.
Thanks, amigos!
Removing USB drive didn't help, and CFE version is the latest possible one. Other ideas?
Double check that you downloaded the correct model, and you did unzip the file.
