chadster766
Recently I've been experimenting with different 5Ghz channel and channel width configurations.
My testing seems to indicate some wireless routers configured for 80Mhz (AC) could failover to channel 36 regardless of the channel you specify. Also many DFS channel ranges don't support or are regulated to not allow 80Mhz. In the upper non-DFS channels 80Mhz may not be allowed as well.
I've used the below Wiki for 5Ghz testing but the driver I'm testing doesn't follow it regardless of the country code I use:
5 GHz (802.11a/h/j/n/ac)
It would be very easy for the average user to not ever notice that their wireless router is not broadcasting on the 5Ghz channel and channel width they specified. In some user testing N performance is close to AC so throughput tests wouldn't alert them to the issue.
Wouldn't the AC protocol 80Mhz easily congest the current 5Ghz channel range including DFS channels with several SSIDs and in the case of non-DFS only two SSIDs? This might not be a big issue since 5Ghz is mostly line of sight with very low building material penetration properties so that could possibly greatly lower congestion between buildings and out in the open.
I'm hoping to can get more clarification on what different makes and models of wireless routers or wireless drivers actually do in the 5Ghz signal range.
