Kim Puleston
Hey all,
I am new and glad to be here. Let me give a brief description of my issue.
I have an RT-AC88U Router that is setup in Wireless Router Mode. My RT-AC88U connects to my ISP router via the WAN port, so it is in a LAN-WAN configuration. I am currently running Merlin 380.62 Beta 1.
My issue is that when I use OpenVPN with an Overclocked CPU and RAM, my router really struggles and both cores on the CPU show massive usage even when there is nothing happening. I ran a Speedtest while connected to the VPN and my speeds are massively limited (5Meg Down). Now if I am to do the same WITHOUT the OC, everything seems to run just fine and I get my anticipated bandwidths (Between 30-40 Meg Down)
I have seen a few people running 1600 Core and 800 Mem on my model of router, as such I gave that a go, I have since lowered the OC (1500 Core 700 Mem)to see if I was reaching to0 high but for whatever reason, when overclocked and using OpenVPN everything goes mad. If I disable VPN then the CPU returns to the standard 5% usage when Overlocked which is what I would expect.
Just so its known the OC was done through SSH using the below commands as usual :
nvram set clkfreq=1500,700
nvram commit && reboot
Please note that this also happend on the previous Merlin release of 380.61 so its not an inherent issue to the latest Beta version.
Any ideas at all ?
Thanks in advance.
Any ideas at all ?
Thanks in advance.
