AC68U locking up
SnoopyTRB
So I'm running in to an odd problem and not sure where to start, hoping someone can help point me in the right direction.
I've had my AC68U lock up on me three times now, progressively more frequently. Only fix is to power off and back on. All times internet becomes inaccessible, cannot get to the router webpage or SSH into it either. Are there any logs that I can go look at to try and figure out what is going on?
The last two times it happened was this morning on 378.52_2 and then again this evening on 378.53. Any help would be appreciated, happy to provide any logs, just tell me where to find them.
[QUOTE="
The last two times it happened was this morning on 378.52_2 and then again this evening on 378.53. Any help would be appreciated, happy to provide any logs, just tell me where to find them.[/QUOTE]
Is your router running too hot by any chance? Can you try another AC adapter?
I don't think I have another AC Adapter to try. I felt the router after the most recent lock up and while it was warm I wouldn't say it felt hot. I did blow the vents out with some compressed air so maybe that will help.
New here, but had too react on this topic!
I'm having the exact same problem it started with the same 2 firmwares, never had issues before..
also i have 2 68u routers one set up as an router the other one as acces point neither one of them was available for acces.
check the NVRAM in tools. if you get close to 65k used the router will crash. plenty of complaints on this topic so we should get a fix some day!
Sent from my iPod touch using Tapatalk
Lock up(hanging or in permanenent loop) and crash is two different thing.
