AC88U link aggregation and AiMesh wired backhaul
Brian F
Hi everyone,
I have been trying to set things up (as per the attached LL design), but I was wondering if anybody can help maybe and stop me if I'm headed in the wrong direction.
I'm struggling a bit to get the LACP to "talk" properly to my switch, but I might have started the wrong way and assumed that setting it Passive on the switch side will work. So last attempt will be to be to setup LACP Active on the switch side and see. But my other issue seems to be that AiMesh node communication is failing when going through the switch (no VLANs configured yet) , so I'm wondering if it's the LACP incorrect setup or will I need additional setup on the AC88U for LACP>>Switch in general, or maybe just if AiMesh wired backhaul is in place.
I have seen a lot of people making use of the link aggregation to connect straight to a NAS, but my requirements are to maximize bandwidth and reliability given my wiring layout.
And on a side note, is there a slight chance we will be able to see in future firmware releases, the ability to kill one radio frequency if a wired backhaul is in place?
Many thanks,
B
You need to enable the bond in the 88U as active. It’s in LAN>Switch Control I think.
So let's forget the AiMesh topic from this discussion (at least for the moment) and focus on LACP.
I have tried various ways to make my Cisco 2960-X talk LACP with my AC88U, but for the love of God, it just doesn't work.
I'm frustrated as I've trolled the internet about setting it up and even troubleshoot this on my switch... but nothing matches my case...
I just need the bare minimum config required for LACP to work, then I can start segregating into VLANs perhaps and other options but, I just need to see it working first.
I'm sure I'm missing something to do with the config on the switch regarding the etherchannel or port-channel but I can't figure it out.
On the Asus I've disabled the Jumbo frame and STP and left only Link Aggregation and NAT Acceleration enabled (attached screenshot)
Anyone can share some switch configs maybe from your device so I can make this work, or am I supposed to follow an exact sequence of config/reboot/plug patch?
I'm very short of pulling my hair out!
Many thanks,
B
I wonder if it’s as the Router and Switch are acting as the switch end of the equation. Most people have an end device like a NAS off of the Router/Switch.
802.3ad is definitely supported switch-to-switch but per this post there are some limitations/changes need to be made to fully utilise it https://community.cisco.com/t5/swit...ch-to-switch-bandwidth-expecting/td-p/2902268
I found something that can impact my LACP.
It looks as though the Asus is sending Fast LACPDUs (1sec) whilst Cisco is sending Slow LACPDUs (30sec)
The trouble is I wanted to force the Cisco into fast LACPDUs but the command doesn't seem to exist.
Yes, I did try to apply the command only on Gi1/0/19 and Gi1/0/20 which are LACP enabled interfaces so should have worked.
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
2960-X#show etherchannel 1 detail
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Gi1/0/19
Port state    = Up Mstr Assoc Not-in-Bndl
Channel group = 1           Mode = Active          Gcchange = -
Port-channel  = Po1         GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/0/19  SA      bndl      32768         0x1       0x1     0x114       0xD
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi1/0/19  FA      1         3497.f621.1038   1s    0x0    0x0    0x3     0x7
Age of the port in the current state: 0d:01h:11m:22s
Port: Gi1/0/20
Port state    = Up Mstr Assoc In-Bndl
Local information:
Gi1/0/20  SA      bndl      32768         0x1       0x1     0x115       0x3D
Gi1/0/20  FA      1         3497.f621.1038  19s    0x0    0x0    0x2     0x3F
Age of the port in the current state: 0d:01h:11m:24s
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:03h:23m:19s
Logical slot/port   = 9/1          Number of ports = 2
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi1/0/19 Active             0
  0     00     Gi1/0/20 Active             0
Time since last port bundled:    0d:01h:11m:22s    Gi1/0/19
Time since last port Un-bundled: 0d:01h:11m:25s    Gi1/0/20
C2960-X#
