Accessing Plex Remotely broken on 376.48_1
jb68
I can no longer access my server remotely on this new firmware, have tried a different router and works fine.
I usually access it by http://(my.ip or DDNS): (port mapped)/web.
I have checked the port forwarding logs and can see the port being forward, I have tried everything, but cannot access it (even tried manual port forwarding and disabling firewall).
Anyone have the same issue?
Try disabling NAT acceleration under LAN -> Switch Control.
That seemed to fix it, thanks.
Do I need NAT acceleration enabled? I have 80mbps/20mbps Connection Speed.
Which specific router model do you have?
What is your ISP connection rated for?
With any reasonably new Asus router (RT-N66U or higher), as long as your ISP is rated at about 250 Mbps or lower, using NAT acceleration or not won't make a difference.
But if you have ~200Mbps to 1Gbps ISP speeds available to you, you'll see that depending on the router and the options or settings you're using, that your max possible WAN to LAN and LAN to WAN speeds are capped by the routers with lower end cpus and NAT acceleration disabled.
What is your ISP connection rated for? BT Infinity -
Asus - RT AC66U
Bt Infinity - 80mbps Down, 20mbps Up
Asus - RT AC66U
Not for those speed, no.
The AC66 can handle up to about 150 Mbps without HW acceleration.
I was having the same issue connection to various services on my server through my DDNS. Thankfully toggling that setting fixed it. For what it's worth, I did not have this issue with an earlier version of your firmware. I think it was 374.xx. I can't recall exactly which exact version I had.
