i was wondering if you could run an additional test on the routers you review.
You usually run tests on the usb/esata drives you connect for speed. but could you also run a test with the drive formated as ext3 as well as the fat/ntfs.
Since most of these routers are linux based and alot of the people who put drives on them would probably permanently leave them attached; a comparison would be nice to see the difference when they are not seeing the slowness of the additional overhead of the ntfs driver.
Thanks,
Thanks,
