Advice on fastest option
hkphooey
Hi guy's
I have just installed BT gigabit FFTP, I get decent wireless speed approx. 500mbps when I'm right on top of the hub 2, which isn't really any use as its right at the back of the house.
I currently have a Deco R4 mesh set up, the base is on the ground floor, and then i have one on the first floor an the third is in my loft conversion.
I have a cat 6 cable running from the BT hub under floor to the lounge with a router repeater and main deco unit connected for wifi at front of the house.
I am wanting better speeds on the mesh system currently its approx 250 on ground and 100 in loft.
What would be the best options please for approx £300 ? was looking at the X55 Deco's but would love some advice please.
I am mainly running firestick 4k and xboxes on the wireless on all levels
Best bang for buck.
Hi @hkphooey
I don't know what is Deco R4.
Deco X55 is a good solution. For long distances, ethernet backhaul can also help.
Hi @hkphooey
Hi
Sorry M4 mesh 3 Pack, unfortunately wired isn't a option for me.
I'm trying to get similar hub wireless speeds in the other rooms.
Just ordered a Asus RT-AX86S Dual Band WiFi 6 AX5700
Which will be here today to replace my BT hub
