MANswers
Hi all,
I have a Asus N66u router, and everything has been working great for the last 2 or 3 years. Today morning when i wake up, i see my all of my devices were not connecting to the internet.
I have a comcast cable internet, with my own Motorola Arris Surfboard 6141 modem.
Upon investigating, i see that the the led on the router looked odd, the led on the 2.4ghz wasnt on, and only 5ghz was working, I usually use 2.4ghz on all of my devices, but upon switching over to 5ghz, internet connection was still dead.
On the Modem as well, the LAN connection LED was off.
I unplugged the ethernet cable and plugged it directly to the working PC, which i mainly used, and internet was working fine directly.
So i assume my router is dead? WHY? end of lifecycle, do routers run for 2-3 years only? yes i do download and stream a lot of stuff.. but not sure, if its wear and tear.
Now if i have to buy a new router, should i go with an Asus, or Netgear nighthawk?
If asus, is ac3100 a better choice or ac3200 or even the rt-ac88u
The house is about 1800 sqft, but in two years we will be moving to a 5000 sqft house.
Apart from that i have atleast a dozen things connected to the wifi. Please guide/suggest.
