AX86U Power Supply
PureSpeed
So I have 4 RT-AX86U that I picked up from a Goodwill. Does anybody know a suitable power supply from Amazon that I can use with it? I can’t seem to find anything really about it except the voltage the watts and the amps. ASUS uses so many different power supplies. It’s tough to find the correct one. I even tried a search on Amazon with not much luck
The amp rating doesn't have to be exact as long as it's => the required amps. Per Asus support you are looking for:
RT-AX86U : 19 V with max. 2.37 A current / 19.5 V with max. 2.31 A current
The only missing piece of the puzzle is the barrel jack size which I unfortunately can't help with. I'm sure someone will chime in with the size.
Thanks for the reply that’s exactly what I’m looking for is the barrel size it’s driving me insane
