[Beta] RT-AC3200 Firmware version 9.0.0.4.380.2695
zoomee
[Beta release]
Security Related
- Modified the access rights of account mode and share mode to asusware.platform path when lighttpd server is enabled. (Très Acton at BAE Systems Applied Intelligence)
- Modified the access rights to specific port of UPnP server. (Thanks to Acton)
- Updated lighttpd server version to 1.4.39 (Thanks to Tommi)
- Restriced access from wan method to enhance security. (Thanks for David)
- Changed SSH and Telnet default access interface.
New Features
- Supported auto dynamic port changing of UPnP server when ports conflict.
- Supported more ASUS Router App new features
- Added traffic analyzer
Bug fixed
- Fixed the GUI issue for reboot scheduler
- Fixed httpd/ Telnetd/ SSH restart issue after LAN address changed
Download: Click Here
The Media Server does not work . On my Smart Tv , at the input list , the icon for Asus Media Server does not appear anymore. Does nobody actually use an external HDD for Media Server ?
Anyways , beginning from version 3.0.0.4.378.7838 it started to not work properly. Will it get resolved in the future or am I supposed to buy a NAS ?
Otherwise the Wi-Fi works well.
[Beta release]
Installing this build fixed restarting httpd every 30 seconds:
watchdog: restart httpd
rc_service: watchdog 483:notify_rc start_httpd
RT-AC3200: start httpd - SSL
but now the admin pages can be very slow.
Does it require a factory reset? A hardware-button factory reset?
After that is it OK to restore a saved config or will that restore incompatible state?
I didn't perform a factory reset, and all seems to be working fine so far.
Only issue I've had with this firmware is that the internet access function for individual devices doesn't work through the browser and is a bit flakey when used through the app
Do you mean device access to the internet or to the router's configuration web pages?
If you mean the latter, I'm having the same problem and wondering if a factory reset will help.
Wish I could get good uptime.. I got about a week and a half on this beta before something went again. Router still responded to pings, and started ssh login, but wouldn't complete, or route anything.
It all seems fine to me. The problem I have is with the section where we can list the connected clients and can enable and disable internet access for each single device - it sometimes works with the app, but doesn't work at all using the GUI
Web pages are way too slow, they need to fix this so more people can test this beta. Went back to previous version because it was useless with the interface that slow.
