Bridging Help: RT-N66U to RT-N66U
Discussion in 'ASUS N Routers & Adapters' started by trek_520, Feb 27, 2013.
  1. trek_520
    trek_520 Regular Contributor
    Aug 17, 2010
    67
    First - sorry for bombarding the forum today. I am just in the midst of it.
    I am trying to bridge the two RT-N66U routers together. I have the latest firmware on both units installed and used the following instructions.
    http://support.asus.com/FAQ/Detail....6A44-9182-C513B58F5B89&p=11&m=RT-N66U (VER.B1)
    I have triple checked the instructions yet I cannot make a connection to 1) the router or 2) the internet.
    Any advice?
    Futher - Can't I shut the wireless off in the bridge device? I really do not want to repeat the connection. I am just looking to use it a bridge.
    Thanks in advance.
  2. Log in / Register to remove this ad
  3. trek_520
    Aug 17, 2010
    67
    To add more detail - I am not interested in it being half duplex or send and receive. I guess I believed that is what a bridge does. The D-Link DAP-1522 can be a true bridge the way I was thinking.
    Also - I see the RT-AC66U has a media bridge mode. I wonder if that has that dedicated mode and shuts off the wireless.
    Thanks again.
  4. trek_520
    Aug 17, 2010
    67
    I am contacting ASUS for some support on this, but I fear this is nothing more than repeating mode and not a true bridge.
    Does anyone know if ASUSWRT has a dedicated bridge mode? I did not see it listed on the specs page.
    Thanks in advance.
  5. trek_520
    Aug 17, 2010
    67
    I can tell you that if you go into wireless under the "professional tab" you can turn off the radio.
    I did install ASUSWRT and did not find any bridge settings that are different from the stock firmware.
    FWIW....
  6. professordave
    professordave Occasional Visitor
    Jan 22, 2013
    29
    Did you ever find out the answer?
    Coincidentally, I was trying something similar, the setup works, but if the main router gets power cycled, and the two devices that are set as bridges are not, they do not reconnect.
    I have an asus ac66u as main router, default settings.
    I have an asus rtn10+ and an rt 12, using default asus firmware, they are set in repeating mode.
    They each have one ethernet wired device directly connected by ethernet wire.
    The goal is to use these asus devices to make two wired ethernet devices wireless.
    I do not want these asus routers to be repeaters, just bridges.
    If I power cycle the rtn12 and rtn10+ last they connect to the ac66u and the wired devices are then "on the LAN".
    But this a problem, that is, if the main router gets restarted for any reason, everything else needs to be restarted?
  7. trek_520
    Aug 17, 2010
    67
    Dave - I did not get it to work.
    I have been working with someone at ASUS in there upper tech support department. Here were his comments.
    - they use the WDS spec and the maximum speed is 54 MBs...
    - WDS mode should shut the radio off in the bridge (on least the band you are bridging with) - Hybrid mode is will leave the radio active. I never got it to work as described.
    - I am told the media bridge mode in the AC66U is going to go away, leaving repeater as the only option.
    So the long and short is it will not act as a true bridge. I have used a DLink DAP-1522 that I will put back into service. It does all the things I am looking for and connects at a fast rate. It does have some Windows Home group issues, but I cannot remember why.
    I wish ASUS would make a true bridge - seems to me it could be done with firmware...
    good luck
Share This Page
