Solved Can I reach my TOR enabled Asuswrt-merlin router from within TOR?
domic
Is there a way/script that shows what IP/TOR domain name within the TOR network my router's TOR "WAN" connection is using so I can bookmark it and access my router within the TOR network from my phone/laptop that's connected to TOR as well?
You may be able to connect, but so will everyone else. Not a good idea.
Yes, but I think not on Asuswrt.
It's possibile under openwrt:
Obviously is the same thing as opening your router on standard internet.
So it's recommended that you use this function to establish an ssh connection to your router
