Cannot change rmem_max
exoxon
Is it not possible to change rmem_max permanently via nano /jffs/scripts/init-start (echo *value* > /proc/sys/net/core/rmem_max)? Every change i made in here survives reboot, except this one goes back and back again to 2500000.
Is there another way to change this value?
Maybe the firmware changes it itself during boot. Try to make the change happen later during the boot process.
Try services-start instead, so it won`t be executed every time there is a router service event occuring.
Yes i am! why on earth AGH changes that?
No idea. Maybe ask the person that created the installer script. @SomeWhereOverTheRainBow ?
proc_optimizations () {
  { printf "4194304" > /proc/sys/kernel/pid_max; }; # Ensure max PID coverage
  { printf "2" > /proc/sys/vm/overcommit_memory; }; # Ensure ratio algorithm checks properly work including swap.
  { printf "2500000" > /proc/sys/net/core/rmem_max; }; # Ensure UDP receive buffer set to 2.5M.
  { printf "0" > /proc/sys/net/ipv4/icmp_ratelimit; }; # Ensure Control over MTRS
  { printf "256" > /proc/sys/net/ipv4/neigh/default/gc_thresh1; }; # Increase ARP cache sizes and GC thresholds
  { printf "1024" > /proc/sys/net/ipv4/neigh/default/gc_thresh2; }; # Increase ARP cache sizes and GC thresholds
  { printf "2048" > /proc/sys/net/ipv4/neigh/default/gc_thresh3; }; # Increase ARP cache sizes and GC thresholds
  { printf "240" > /proc/sys/net/netfilter/nf_conntrack_tcp_timeout_max_retrans; }; # Lower conntrack tcp_timeout_max_retrans from 300 to 240
  if [ -n "$(nvram get ipv6_service)" ]; then #IPV6 proc variants
    { printf "0" > /proc/sys/net/ipv6/icmp/ratelimit; };
    { printf "256" > /proc/sys/net/ipv6/neigh/default/gc_thresh1; };
    { printf "1024" > /proc/sys/net/ipv6/neigh/default/gc_thresh2; };
    { printf "2048" > /proc/sys/net/ipv6/neigh/default/gc_thresh3; };
  fi;
  fi;
That script shouldn`t blindly write system values without checking first what the current values are. Otherwise, it might override something else that needs different or higher values (like the user does here).
