Client traffic Grafana dashboard on RT-AC88U with MerlinWRT
keydam
Hi there,
I'm looking for any solution to send the traffic by device to InfluxDB or Prometheus, to display the value in a Grafana dashboard.
As said in the title, I have a RT-AC88U router with the last supported version of MerlinWRT.
Has anyone already done this ?
Damien
Care to share what you found to work for you?
Interesting to see.
Am I right in thinking this won't report correctly if using hardware acceleration?
Thanks for confirming. My working assumption is they won't be (similar data gathering I had before stopped working when I had to enable CTF as it bypassed the CPU/kernel) but I may have a play around to double check.
I checked the scripts. In both cases, scripts are done in a way you're using your own influxdb. I am using hosted cloud version of influx. In my case I don't have username&password, but token. Any idea?
